The next evolution of USB technology: a charger that provides high-speed charging from the wall and on-the-go.
A combination of the reliability of a wall charger and the convenience of a portable charger. It takes the best of both charging worlds to create Anker’s most versatile charger.
Charge your USB-C Laptop and the internal battery via a wall socket
Take it on-the-go as a portable charger
30W USB-C Power Delivery Charging (Wall Charging Mode)
PowerCore Fusion delivers convenient, high-speed charging from the wall. The 30W USB-C Power Delivery output will charge anything from iPhone to Samsung to USB-C laptops and more.
That statement is false in a sense, iphones generally do not turn off chargers when plugged in because they trickle charge and is always drawing power. Had the user tried this with a different device other than a cell phone they would most likely have seen it start to charge the internal battery once said device was fully charged
If that is true, Anker should edit their literature to say so. I don’t see it in mentioned in compatibility. It’s reasonable for Anker to not know on launch if there’s a problem with specific devices but as soon as they get feedback they should tweak clarify. The comment is 13 days old.
No-quibble return really helps forgive as Anker can’t know every foibble. They should though understand issues and update compatibility in a timely fashion.
As the Fusion 5000 PD device, I bought 3 of the original non-PD years ago and gifted them to people who are, cough, shall we say in a habit of not remembering to recharge the Powercore I had gifted them prior. I didn’t keep myself as I prefer a dual port charge and plug in Powercore + device as then I got more options, but I’m a geek. I see the role these Fusion have and like the creativity.
